how to get cruise control working after engine swap.
Old Jul 8, 2022 | 03:13 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
swapped a 5.3 with a Holley TerminatorX into my 89 IROC. got the cruise control cable hooked up to the throttle body, but can anyone tell me what wires to hook up to what to get the cruise working again?
it's a really nice thing to have on long interstate jaunts..
Old Jul 21, 2022 | 03:13 PM
novaderrik's Avatar
Car: 86 Camaro
Re: how to get cruise control working after engine swap.
so no one has gotten the factory cruise control to work as a standalone setup?
Old Jul 21, 2022 | 08:13 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
The Holley Terminator does not support Cruise Control. Dakota Digital has a stand-alone system for adapting CC. I used an E38 ECU, reprogrammed to the SSR configuration for CC with a manual transmission and using the GM stalk controls.
Old Jul 21, 2022 | 10:18 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Well, I'm unsure I fully understand, but I'll throw this info your way. I swapped in a 350 and removed the computer, which grounds the CC. A reground did the trick. If that's the least bit helpful, the following link shows what I did:
https://www.thirdgen.org/forums/engi...-function.html
JamesC
Old Jul 21, 2022 | 10:57 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
JamesC
That is awesome, thanks for sharing. I want to get mine working now that I know I can keep it.
Old Jul 22, 2022 | 09:20 AM
JamesC's Avatar
Glad to help.
JamesC
Old Jul 26, 2022 | 06:16 PM
novaderrik's Avatar
Car: 86 Camaro
i want to use the factory cruise control as a standalone.
looks like one other guy already answered the question.
Old Jul 26, 2022 | 06:20 PM
novaderrik's Avatar
Car: 86 Camaro
JamesC
at is exactly what i was looking for. thanks.
that will cross off one more thing on my list to make the car as functional as it was with the stock TPI 350..
next up is the AC..
Old Aug 6, 2022 | 01:52 AM
novaderrik's Avatar
Car: 86 Camaro
finally got this done today.
simply grounded the black wire with a white stripe in the plug down by where the ecm was and the cruise works perfectly now.
Old Aug 6, 2022 | 07:43 AM
JamesC's Avatar
I'm glad all went well.
JamesC
Old Aug 6, 2022 | 11:22 PM
novaderrik's Avatar
Car: 86 Camaro
JamesC
it was such a simple thing to do and should have been obvious to me from looking at the wiring diagram.
89RsPower!
Sep 3, 2009 01:39 AM
