Multi-purpose fuel pump relay
Old Jul 12, 2022 | 07:53 AM
tylrdenny's Avatar
Car: 1989 Camaro RS Convertible
Engine: 5.0 L, 305
So I just bought a 1989 Camaro RS convertible. It needs a lot of work from electrical to body work. But I found that the multi-purpose fuel pump relay was un-plugged and then someone jumped the plug with a wire, the car does run and drive great, but the fuel gauge is wonky. Does anyone know why that was done? Could the relay be bad? I'm grateful for any help, thanks!
Old Jul 15, 2022 | 08:36 PM
tylrdenny's Avatar
Engine: 5.0 L, 305
Re: Multi-purpose fuel pump relay
Ok, so I took the relay apart, the contacts were black so I replaced the relay.
Old Jul 16, 2022 | 10:22 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Seems like jumping that relay would have the pump running all the time? I wonder if it was running off the oil pressure switch?
Old Jul 16, 2022 | 10:38 AM
tylrdenny's Avatar
Engine: 5.0 L, 305
So the guy I bought it from had just put a new fuel pump in the car and installed a battery cutoff switch. He said the battery had a parasitic drain. So the pump was probably running all the time.
This is how it was jumped
Glowsock
Jul 24, 2025 03:15 PM
Chevy86 IROC-Z
Dec 12, 2017 03:58 PM
eyeroc87
Mar 10, 2017 04:56 PM
chosen1
Jan 10, 2009 09:40 PM
