Fuel pump relay
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Fuel pump relay
I know exactly where the fuel pump relay is at,,, but which one is it? There are three relays on my driverside firewall right next to the brake booster deal. Is there a way to identify which one is the relay? Any advice would help. Thanks fellaz.
Ohh. My Camaro is a 1986 IROC-Z.
Ohh. My Camaro is a 1986 IROC-Z. Senior Member
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: Fuel pump relay
What engine did the car come with stock? My 305TBI the pump relay is the on the firwall as you stated, the one closest to the drivers side fender.
Car: 1986 IROC Z28
Re: Fuel pump relay
On my 86 IROC stock 305 TPI my fuel pump relay is the one farthest to the left of the three(closest to the brake booster)
Re: Fuel pump relay
Cool thanks guyz but, I dont have a TBI, mines a TPI and everything is stock other than the 305,,,, I dropped in a 350. Well then, Im going to have to shoot the duck in the dark. Does anybody have theyre relay in the middle?
Car: 1986 IROC Z28
Re: Fuel pump relay
Another way to possibly tell is by taking the relay off the firewall, my original fuel pump relay used a five pin connector, but when you looked at the relay itself it only had four pins... The burnoff and the Maf power relay were five pins. However, if they were ever replaced that might not help you, because the replacement relays I was given by NAPA are all the same part #, and are all five pin. Another way is you can look up the part number on th relay and see what it cross references to... My original set of relays were actually stamped "MAF Power" and "burnoff" and my fuel relay only had a part number, but my fuel pump relay looked much newer than the other 2, so I think it was replaced by the PO once before.
If your just looking to replace it, my car now uses the same five pin relay for all three, with no drivability issues. I was concerned that it wouldn't work, because the guy at the parts store doesn't know a thing about cars other than what his computer tells him, but he was right for once...
Re: Fuel pump relay
Car: 87 T-Top GTA
Re: Fuel pump relay
1) MAF Burnoff relay org.#14078907 is replaced by #10094701(closest to engine)
2) MAF Power relay #10067925 (middle)
3) Fuel Pump relay org.#14078907 is replaced by #10094701(beside driver side fender)
***All part #'s are AC Delco Parts***
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
Re: Fuel pump relay
to find the right one I would go by the wiring color codes going to the relay, should have tan/white, drk grn/white, org, blk/wht, red
Re: Fuel pump relay
OK, so 3 relays, here we go: Listed as if you are looking right at them (TPI setup)
3) Fuel Pump relay org.#14078907 is replaced by #10094701(beside brake booster)
Car: 87 T-Top GTA
Car: 1986 IROC Z28
Re: Fuel pump relay
Strange, my 86 is different... Of course there's enough extra wire that I can swap them from relay to relay. I'll have to check it out but mine was setup differently than yours, possible difference between the 86 and 87 IROC's? Witnlyns right if not positive check the wires to verify. It's possible the PO of my car messed around with things, I've had to fix a few wires twisted and held together with electrical tape, he was a hack!
Car: 87 T-Top GTA
Re: Fuel pump relay
Re: Fuel pump relay
They get switched around. Most of the time, the relays are mismatched. Best way to figure them out is by the wire color.
Car: 1985 Camaro Iroc Z28
Engine: 305 5.0 TPI
Re: Fuel pump relay
Holy smokes. I would have labeled them 1 2 & 3 with masking tape, pulled them all off, and inserted them 1 by 1 until i heard the fuel pump when you turned the key on. Sorry so late (Like years) but damn lots of time wasted.
