How to hard wire a fan
Old Jan 19, 2002 | 08:00 PM
CaptainMidway's Avatar
I was wondering if anyone could tell me how to hard wire a fan on a 91 RS. I just need this as a quick fix.
Old Jan 20, 2002 | 03:54 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Not raggin on ya or anything but, if you did a search or just made an efort to scroll down the page, fans have got to be the most popular topic in this forum......
Here's 1 post from lower down the page
https://www.thirdgen.org/techbb2/sho...threadid=76381
A link from within that page....
https://www.thirdgen.org/techbb2/sho...threadid=75207
Using the search feature would probably result in better than 250+ more topics about fan wiring with at least one helping you out.
My apologies if I come off as rude... do a seach just to humor yourself tho & you'll catch what I mean...
Old Jan 20, 2002 | 11:50 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Here's a really basic diagram, you can use a mini toggle switch to apply the ground instead of the ECM if you'd like.
Old Jan 21, 2002 | 08:02 PM
Thanks for the info guys
Old Jan 22, 2002 | 01:43 PM
mtccl's Avatar
Find the wire coming out of the thermo-switch on the engine. That is a ground wire that activates the fan when the switch closes. Run a wire from the wire to a switch in the dash and ground the switch to the body. Now when you turn on the switch the fan will come on. It will also operate normally with the switch in the off position. Bingo....you now control a fan. Good Luck!!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
apie2546
Aug 8, 2015 07:12 AM
