Wiring help please
Car: 1987 Trans Am GTA
Engine: 355 Chevy
Transmission: Y-56
Axle/Gears: 9 bolt 3.23
Wiring help please
Have a trans am gta I bought that was gutted basically a roller my question is front wiring for headlights and headlight motors how does this wiring route does it all stay on back side of radiator support or cross on the front side need help please if anyone has pics that would be a big help too
Car: 1983 Z28
Engine: 385 Fastburn
Re: Wiring help please
Camaro headlight wiring runs in a backwards L shape from a big plug on the driver side firewall to the radiator support, then across.to the passenger lights.
I would assume firebird's are the same but can't speak to the headlight motors.
The Exterior Lighting for the Front of "1G2F Cars" (Fire-Birds)...
Goes from the C100 Bulk-Head and HeadLamp-Module Electrical Connectors on the Driver's side of the Fire-Wall.
(Right side of Image).
Down by the Vacuum Power Brake Booster and Master-Cylinder...
Down the Driver's side Frame-Rail with the Evaporative Emissions Lines...
To the Head Light, Parking Light/ Signal Light, and Fender mounted Side-Marker/ Signal Light (on the driver's Side).
Then across the Radiator Support to the Head Light, Parking Light/ Signal Light, and Fender mounted Side-Marker/ Signal Light (on the Passenger's Side).
(Left side of Image).
