Need help with a CS-130 alternator form a 7.4 liter not charging
Old Sep 20, 2022 | 03:34 PM
  #51
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need help with a CS-130 alternator form a 7.4 liter not charging
Quote:
Originally Posted by 91banditt2 View Post
The alternator is low mounted and in relative close proximity to the pass. side header and they get hot pretty fast, maybe that is contributing?
Originally Posted by RBob
That may very well be contributing to the lower voltage. The cooling air enters the rear of the alternator and exits the front. So it is drawing hot air in directly from the header.
RBob.
Any luck in measuring the incoming alternator air temperature that is used to cool the alternator?
RBob.
Old Sep 20, 2022 | 03:40 PM
  #52
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
The saga continues……..
stop at my location AZ and my new ACDELCO alternator failed…..4 times 😬
Just to check to be sure I asked the manager to look up both the 91 Firebird and the C/K 2500 Chevy truck to be sure both use the same test cart adapter plug, both used the same plug.
Now to get an Amazon return started 🤦🏼
EDIT: And just because, I took it to two other parts stores to have it tested and it passed twice 💁
Old Sep 22, 2022 | 06:25 PM
  #53
91banditt2's Avatar
Engine: 5.7 HSR
Alternator is charging!
Fixed the chassis ground wire from the negative cable to the firewall and added a 2 gauge ground from the pass. side head to the alternator and replacing the belt seems to have cured the squealing.
rrdogface
Feb 23, 2015 05:50 AM
ninety1z
Nov 29, 2009 06:38 PM
b_pereira
Apr 3, 2009 04:21 PM
alabama_lowlife
May 23, 2006 03:20 PM
snflupigus
Jul 1, 2003 01:30 PM
