Alternator not charging
Old Nov 28, 2009 | 03:17 PM
ninety1z's Avatar
Car: '91 Z28
Engine: 5.7
I have a '91 Z28 that has a alternator issue. The alternator will only put out 11.30-11.99 volts. The battery, starter, and alternator are all new. I have two new alternators and the same thing happens with both. I only drive the car once in awhile and it always fires up after sitting. Once running it just won't charge what it should be charging. I unhooked the wire that goes to the battery and had no voltage off the terminal on the back off the alternator. Shouldn't I have about 14 volts here if the alternator is putting out? I have checked all grounds and don't see any problems. Any ideas?
Old Nov 28, 2009 | 04:13 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Alternator not charging
how many wires is the plug that goes to the alternator?
one of those is an "excite wire" that needs to be hooked to 12v ignition to kick the alternator on when the car is running.
if all the wiring is in tact, it sounds like you have a bad diode in the alternator.
it is very common with a cs130 alt.
Old Nov 28, 2009 | 05:20 PM
ninety1z's Avatar
Car: '91 Z28
Engine: 5.7
I have two wires that go into the plug on the alternator, both have power with the ignition on.
Old Nov 28, 2009 | 06:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
take it off and have it checked. its dead.
Old Nov 28, 2009 | 07:26 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Make sure the the brown wire hasn't been hooked directly to keyed 12V. It should go to the volt gauge. It needs to have some resistance or it will fry the alternator. @ 400 ohms or a light bulb is enough.
Old Nov 29, 2009 | 05:21 PM
ninety1z's Avatar
Car: '91 Z28
Engine: 5.7
I found my problem today. I had my fans wired up to run off a switch and was getting power from the fuse box where the fan fuse should have been. I guess the fan and alternator charge wire are on the same circuit. So I put the fuse back in and the alternator charges what it should charge.
Old Nov 29, 2009 | 06:38 PM
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
good. I had a problem with my alternator a wile back, previous owner wired it wrong and it fried.
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
