Ac delte box
Ac delte box
Ok so im putting a ac delete box in my car but would like to wire my blower motor up stil lfor heat but i no longer have my ac head in the car gauges will be in its place nor do i have a ac harness as it was removed and cut by previous owner so how would i fo about wiring the blower motor to the **** switch or just a toggle to full on
Re: Ac delte box
We can help you wire the Blower Motor using the Blower Motor Resistor for multiple Fan Speeds...
But first you need to tell us how you plan to control the Blower Motor.
You stated that you do Not have a HVAC Control Head any more...
Do you have the Cable that moves the Temperature Door?
You need a way to adjust the temperature of the Air.
