BraveTECH - Firebird LED Pop-Up Headlight Delete Kit (Bolt-On, Plug N Play)
Old Dec 6, 2022 | 12:52 PM
BraveTECH's Avatar
Former Sponsor
Car: 1990 GTA
Engine: 5.7
Website: https://bravetech.ca/
Price: $537.00 USD for the pair. This may fluctuate over time.
Hi Everyone,
This is a product that I have been working on for a while.
Features:
- F
ully Bolt-On and Plug N Play.
- Industrial High Output LEDs.
- Low Beam,
- High Beam,
- Sequential (Or Non Sequential) Turns Signals.
- As the unit is recessed into very limited space in front of the factory headlight bezel, I needed to add a cooling system for the high output LED Display. There are cooling fans and air filters on each unit. The cooling fans are only active while the High Beams are on.
The YouTube video is of the original Version 1.0. Some features have been adjusted since the video was taken.
Please note that they take 1 - 1.5 weeks to fully assemble and test. There is currently a waiting list for them. Please feel free to email me to be added to the waiting list.
Bravendirk@gmail.com
Old Dec 6, 2022 | 03:06 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: BraveTECH - Firebird LED Pop-Up Headlight Delete Kit (Bolt-On, Plug N Play)
do you plan to make a version specific to the 82-84 firebirds? the early year firebirds have a different shape to the front of the headlight bucket. the outside edge is more square than the later year ones.
i'd be interested in a set if you can provide a housing for the early birds. i probably have a spare you can borrow to take measurements from.
Early design
Later design
Old Dec 6, 2022 | 08:02 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Early design
Later design
I did not know this!
Old Dec 12, 2022 | 12:26 PM
BraveTECH's Avatar
Former Sponsor
Car: 1990 GTA
Engine: 5.7
[QUOTE=battmann;6487209]do you plan to make a version specific to the 82-84 firebirds? the early year firebirds have a different shape to the front of the headlight bucket. the outside edge is more square than the later year ones.
/QUOTE]
Hi there,
Thank you very much for the information. I also was unaware that the older style had a more squared shape.
If there was sufficient interest in kits for the earlier model, I would consider designing a version for them. Unfortunately, it would be a rather significant time investment to design another version, as it would also require a new circuit board. I'm not sure what would be the best way to determine the interest.
I do really appreciate the offer the lend me the headlight bezel for measurements.
Braven
Old Dec 12, 2022 | 01:15 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Looks like another nice product from BraveTECH.
Having been made with the curvature of the 85-92 bezel, it will probably fit inside the 82-84 squared bezel. But if it had been made to fit the earlier squared bezel, then it definitely wouldn't fit inside the newer bezel. The old, "round peg in a square hole vs a square peg in a round hole," thing. So, at least, it's likely work in all model years. It just won't be a perfect fit at the squared end of the 82-84 bezel.
And for people who are into a pop-up delete, which I, personally, am not, VFN offers a couple of full-length fiberglass hoods that are NOT cut out for the headlight doors. Seems like a good combination, so maybe one product will create interest in the other.
Braven dirk
May 12, 2024 08:29 AM
Twin_Turbo
Fabrication
45
Feb 18, 2024 02:54 AM
Blue_Thunder
Aftermarket Product Review
16
Oct 6, 2021 07:48 PM
ericjon262
Members Camaros
Feb 11, 2013 08:59 PM
Shagwell
Nov 4, 2009 04:44 PM
