Odometer gear don t turn
Old Dec 28, 2022 | 05:47 PM
mikiman's Avatar
hello. On the 1990 Firebird 3.1 the odometer does not work. I have disassembled it to see if it had the gear that moves the motor broken, but it is not. I try to turn it with my fingers but it doesn't turn. I'm afraid to break it. how do you unlock it?
Old Dec 28, 2022 | 05:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Odometer gear don t turn
Has the gear turned yellow and sticky? It could be stuck to the shaft or the motor has failed
Old Dec 28, 2022 | 06:31 PM
mikiman's Avatar
it is black and not sticky. I put lube on it. I have separated the motor
Old Dec 29, 2022 | 08:23 AM
mikiman's Avatar
Trying to turn it I broke the gear. so I'll look for a replacement in km/h for the v6
Old Dec 29, 2022 | 09:55 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Might as well plan on replacing the tripometer gears while you are in there. Those are probably bust too.
I don't reset my trips anymore in the GTA because whenever I do, half the time it won't work any more. I'll probably find nothing but dust and grease in there when I open it and wonder how it even worked at all.
I_R_O_C_Z_2_8
Dec 31, 2009 10:05 PM
350sbcRX7
Mar 22, 2007 03:05 PM
hurricanerugger
Dec 14, 2002 03:17 PM
Nasty_Bird_'90
Jul 21, 2002 06:50 PM
Camaro3051992
Mar 27, 2002 11:21 PM
