Berlinetta lighting issues
Old Jan 22, 2023 | 12:16 AM
_84Berlinetta's Avatar
When I got the car the low beams were on all the time as soon as the key was turned on. Looked through alot of threads regarding berlinettas on here and was able to get my lights working again by cleaning the control pod and replacing a relay in the lighting module. Now the issue im having is when you turn key on everything works perfectly (can turn all lights on and off with controls) until you start the engine and then low beams come on and will not turn off and no other controls work until you shut it off and unhook battery to reset the module. Does anyone know if it reacts this way when it looses a certain input momentarily like pwr, gnd or ign?
Also I swapped 383 into it with edelbrock efi system, does anyone know if I can run the bar graph tach directly off of the tach output from ecm or does it still need to go to distributer with a tach buffer? Cluster in the car is fried so I have not been able to test.
CanadianBeast
Feb 22, 2026 08:17 PM
Dracul
Dec 12, 2007 05:51 PM
Klortho
Jun 30, 2005 06:03 AM
StealthElephant
Apr 15, 2004 12:24 PM
bombero437
Aug 20, 2001 10:02 PM
