1985 Trans AM Turn Signal Doesn't work
Car: 1985 Pontiac Firebird Trans AM
Engine: 305 Small block Chevy TPI
Transmission: There
Axle/Gears: Leaking
I currently am having trouble with the turn signals in my '85 TPI, when you use hazards they will turn on in sync like normal but if i try using the turn signals they turn on but wont blink as they should and stay solid, I have already been down new bulbs and checking wiring and a new flasher but every time I go to use the turn signal I hear a click from this box which I'm sure could be the problem but I'm not sure what it is, if you could give tips or even tell me what this box by the ECU is that would be great.
Car: 1984 Trans AM
Transmission: 700-4r
Re: 1985 Trans AM Turn Signal Doesn't work
Check your grounds. The flasher can be bad from new. Flashing is based on resistence in the bulbs in total. Not enough resistence, no flash. Even one bad dead bulb will reduce flashing. I would try another analogue flasher assuming u are not using led bulbs.
breathment
Apr 30, 2003 08:42 PM
