right turn signal on the dash does/doesn't work!???
Old Nov 23, 2009 | 04:05 AM
aza454's Avatar
Car: 1987 Chevrolet Camaro RS
Engine: 2.8L MFI V6
Transmission: Auto w/Manual OD
Ok guys, weird problem for you. When I turn left and right the turn signals on the dash work fine, but when I have the headlights on the right turn signal light doesn't work on the dash (the signal itself works fine)...
Any thoughts?? (keep in mind this is a RHD car as I'm from Australia so the issue could be conversion related)
Old Nov 29, 2009 | 11:07 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: right turn signal on the dash does/doesn't work!???
Sounds like a wire is grouded.Maybe the headlight switch or somewhere on the clusters printed circuit board.Just guessing though.
Old Nov 29, 2009 | 07:10 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
did you replace any of the light bulbs ?
bc i change my taillights and its doing the same thing !
iam thinkin it might be a wrong bulb or it might be a dual filiment bulb ! iam check tomorrow !
it happen to me when i got my 83 cutlass supreme ! the guy i got it from but the high and the low headlights in backwards. the also installed the tail light bulb and the brake light bulb in backwards in the tail light ! i post in the morning when i find out whats goinjg on with my car !
Old Dec 1, 2009 | 02:51 PM
THEBEAST84's Avatar
hey there ! i fix my issue today ! for me it was my driverside taillight bulb ! all i did was switch around it and it worked fine ! i thought it waz a ground issue but it only happen when i replacent the taillight goodluck !
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
