Right Turn signal doesn't click, stays on solid.
Old May 5, 2007 | 03:09 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Hey guys, the other day I had a light burnt out, so I did the regular thing of, well, changing it.. I put the same bulb back in, and it worked fine. The next afternoon I noticed that it didn't blink, but it now, just stays a solid light when I hit my right turn signal. The rear and front work. What could be doing this? This car is killing me with frustration..
Old May 5, 2007 | 09:41 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Re: Right Turn signal doesn't click, stays on solid.
Replace the bulb.
Old May 7, 2007 | 02:14 PM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Originally Posted by rhomanski
Replace the bulb.
Thats an indication that your bulb is bad.
Old May 10, 2007 | 10:09 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
What they mean is that if one of your bulbs is of a too low wattage then the blinker relay doesn't get enough current to work with. Check for correct type and position of the bulbs.
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
