Turn Signal help needed
Old Mar 26, 2023 | 06:20 PM
Bigtubs's Avatar
Car: 1986 Z28, 1989 RS
Engine: 6.0 LQ4
Transmission: TH350
Axle/Gears: Stock, 4:11
Okay, got car, someone has been playing under the dash alot.
Dash was out, steering column was out, now putting it together.
Computer, heat, a/c removed and converted to auto from 5 speed
Engine electronics are completely separate from car wiring.
Have:
headlights (high and low)
hazard lights
running lights
brake lights
dash lights
reverse lights
Do not have:
Turn signals
Thanks in advance for the help
Old Apr 2, 2023 | 03:33 AM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: Turn Signal help needed
When you activate the turn signal switch does anything happen? Can you hear a click? Have you checked the turn signal relay, turn signal flasher?
willhewitt00
Apr 9, 2022 02:35 PM
Oldpackrat
Dec 17, 2017 11:41 AM
High~Cruzin
May 28, 2013 10:17 PM
Avernus
May 23, 2008 10:53 AM
