91 firebird TPI engine harness in a 91 Z28.
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Hey posting here to see if anyone has any experience adapting a firebird engine harness to a Camaro.
I understand that the batteries on the other side and I can't figure out how that becomes a problem for hooking up any part of this harness.
I'm sure there's something that would need to be extended potentially but I can't see that being a huge problem.
If anyone has any experience here please let me know.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 firebird TPI engine harness in a 91 Z28.
@John in RI is the only difference battery cable connection and ccp wire length ?
figured you might know 😆
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If BOTH cars are TPI :
Fairly certain that the conflicts your going to run into are related to the HEADLIGHT harness. The Firebird Headlight Harness that connects to C100 is going to have the Firebird pop-up headlight wiring that is not needed for the Camaro.
TBI cars used a different electric Speedo wiring configuration ( buffer compared to the ECM ) so if dealing with a TBI harness that will need to be accounted for.
You can visit this page to get all the C100 and C207 information for the 91 Camaro and the 92 Firebird you will need to look over to be sure. https://berlinetta.info/tech.htm
excaliburr2000
Sep 30, 2009 12:42 PM
