'91 T5 speed sensor
Old Apr 20, 2023 | 04:47 PM
danderson's Avatar
'91 T5 speed sensor
Curious if anyone might be able to identify this speed sensor on my '91 T5. The plug style is different than the harness connector, but hoping that maybe it's the right wave and pulse and I can just adapt to it.
Old Apr 20, 2023 | 06:25 PM
WildCard600's Avatar
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Re: '91 T5 speed sensor
What are you trying to adapt it to? Appears to be the correct speed sensor that came on the cars that didn't have cable speedometers.
Old Apr 21, 2023 | 08:06 PM
danderson's Avatar
I say "adapt" because the connector style is different thany connector, so I wasn't sure if there was a difference for certain years, or if this was for a different T5 application.
This sensor is a barrel style plug where the pigtail on the car is the style in the other attached photo
danderson's Avatar
For reference too, just running stock TBI setup
Old Apr 21, 2023 | 08:27 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Weird. My '89 TBI has the correct connector, it was the same for all model years that had the electronic sending unit in the transmission as far as I am aware.
Shouldn't be a problem to just adapt it with a couple of plugs, it doesn't even matter which wire is which as it's a AC signal.
Old Apr 22, 2023 | 12:17 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
danderson: The speedo sending unit in your pics is from 84-89 Thirdgens. There is also a second style that was used in the 90-92 cars. Both of those types of T5 electric Speedo Sending units are very hard to locate these days.
It sure looks like simply changing the plug will work for you. I have never done it,.. but the 88 and the 91 shop manual both describe a 4000 PPM sensor,... So I assume that swapping to the correct plug is all you'll need to do.
P.S. Be sure to verify that both your plastic Speedo gears are correct while your in there !!
Old Apr 22, 2023 | 12:30 PM
Car: 1989 Trans Am
Engine: sp357
Transmission: TKX
Looks like John is on the money as usual. Found this pic of the '90+ sensor courtesy of member 1froggy1 and sure enough has the different plug.
Old Apr 22, 2023 | 01:17 PM
danderson's Avatar
That makes a lot more sense, thanks John! And confirming the 4k PPM for both us also reassuring. I found a harness from Michigan Motorsports to use the 90-92 sensor with the 84-89 harness, too bad it's not the other way around.. lol. But simple enough to find a female pigtail for the newer H11 style connector and the older male weather pack
https://www.michiganmotorsports.com/...89-tbi-tpi-gm/
Old Apr 23, 2023 | 04:26 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I hope that works for you, but my from recollection that sensor is a 2000 pulse.
Old Apr 23, 2023 | 05:35 PM
John in RI's Avatar
I wasn't 100% positive,..... so I checked before posting.
84-89 style VSS:
From the 85 Camaro/Berlinetta Shop manual:
From the 86 Firebird Shop manual:
From the 88 Firebird Shop manual:
90-92 style VSS:
From the 91 Camaro Shop manual:
Old Apr 24, 2023 | 09:42 AM
Dyno Don's Avatar
Good info, I knew it put out 2000 somewhere.
Old May 25, 2023 | 08:15 PM
danderson's Avatar
To follow up on this, now that I've had it out driving - sensor works perfect and speedometer is about spot-on. Thanks again guys for the help!
Dennis-Z28
Nov 20, 2008 10:34 PM
NORTHSLIDER
Nov 11, 2007 10:16 PM
