T-5 WC speed sensor - leak
Old Nov 19, 2008 | 12:04 AM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Hello all,
I have a 1991 with the T-5 and it is leaking at the speed sensor. The O-ring is nice and fresh but it looks like the leak is from inside and is seeping out where the speed sensor shaft is (there is some play side to side). Has anyone else had the speed sensor wear out? car has 120k miles. Oh yeah, question was it looks like the speed sensor is higher than the fill plug on the other side so there is no reason it should leak right, it should be above the fluid level? I also can't locate a new sensor.
Old Nov 20, 2008 | 10:28 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: T-5 WC speed sensor - leak
Had a similar issue when I had a shop install mine to get out of a ticket. Even though it's higher then the fill plug ATF still gets distributed through out the case to lubricate everything. All the guy did in my case to solve the issue is install a new bullet with a little RTV and 2 years later still no problems.
Old Nov 20, 2008 | 10:31 PM
Dennis-Z28's Avatar
Bullet?
Old Nov 20, 2008 | 10:34 PM
WIll36's Avatar
Engine: 355, 408
the piece that is inserted into the tranny that holds the speedometer driven gear
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
MY87LT
Aug 17, 2015 08:43 AM
mizz0313
Aug 12, 2015 06:45 AM
