Holley 7” dash tach
Old May 10, 2023 | 04:36 PM
Hatya's Avatar
Holley 7” dash tach
Hi I need help getting my 7” dash tach going. This car has a 350 tuned port from an 89 trans am, I pulled tach signal off of the correct white wire on the coil plug.
According to the Holley dash i/o instruction i originally connected to the RPM input and got a very erratic tach reading. I just made some changes connecting the tach lead to pin B26, and yes i have the ground lead connected to pin 19 and I get no tach reading now.
Is this a coil negative tach signal or should i treat this as a rpm input and reconnect to I/O 3 or 4 which support RPM input which was giving me an erratic signal. Ive read some threads talking about a tach sensor filter. Im frustrated lol. Any help appreciated
Old May 10, 2023 | 04:40 PM
Re: Holley 7” dash tach
You say "erratic", describe in more detail.
Old May 10, 2023 | 10:38 PM
Hatya's Avatar
At idle the tach bounce between 2-4k just touching the throttle will show 6k and it bounces all over when cruising.
Old May 11, 2023 | 09:41 AM
MSD in the system?
Old May 11, 2023 | 12:39 PM
Hatya's Avatar
No mad box just standard gm ignition for a 89 tuned port.
ULTM8Z
Jan 3, 2015 10:03 PM
Racer3313
Oct 4, 2003 08:19 PM
Gator_Z28
Feb 6, 2003 05:10 PM
