Help with tach
Old Feb 4, 2003 | 09:45 AM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
Help with tach
I took my needle off my stock tach yesterday and now it reads 500rpm less. Is there a way to make the tach reset itself? If not how could i correct this?
Old Feb 4, 2003 | 09:57 AM
MdFormula350's Avatar
maybe take it off again, when the car is off and try setting it back to zero.
just a guess.
Old Feb 4, 2003 | 10:12 AM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
I've all ready tried that.
Old Feb 4, 2003 | 10:55 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i wish my tach was only off by 500 RPM!!!
Old Feb 4, 2003 | 12:27 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
do you remember what your tach idled at when the car was warmed up before you removed the needle? if so, just start the car and let it warm up, then take the needle off and place it at your normal idle rpm's.
Old Feb 4, 2003 | 02:09 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
lol, amen to that
Old Feb 6, 2003 | 10:20 AM
Gator_Z28's Avatar
Car: '86 Z-28
Engine: 355
Diabolical, I tried that and its fixed good enough. I can live withit being off only by a 100.
Old Feb 6, 2003 | 10:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
unfortinatly my picture is not showing, but it was a shot of my tach pegged while i was on the dyno, i was watching the dyno read-out for my REVS,and pegged out the tach it is off by that much.
Old Feb 6, 2003 | 04:34 PM
Xceleratemaro's Avatar
or you can get a auto meter he he its only 105$
Old Feb 6, 2003 | 05:10 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Try turning your iginiton key to the position just before cranking the car. All the gauge needles should boucne around and settle to their approprate positions. The tach should be at zero, if the needle isnt on zero then put it there and then start up and see if its reading correctly then.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
