Tachometer needle bounces after 3000 RPM
Car: 87 IROC-Z
Engine: 5.7
Axle/Gears: 9 bolt borg warner
When revving the engine or accelerating once engine RPM hits 3,000 RPM tachometer needle starts bounching but engine runs smooth no misfires, any ideas?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tachometer needle bounces after 3000 RPM
Contact Cajun tach shop the thirdgen tachs are known to be inaccurate
Car: 1992 Teal RS
Engine: 350 Carbed
Axle/Gears: 4th Gen Rear 3.42
You can contact Cajun, but their probably gonna tell you to just by their replacement board: https://www.ebay.com/itm/14336635370...mis&media=COPY
I bought one Thursday evening, had it in mail today, installed tonight, my tach is back. I sure wish someone made boards for the speedo!
Transmission: Pro-built 700R4
Does your car have an MSD box installed? If so, that's why. You can use their tach adapter to fix the issue.
