Tachometer
Old Oct 4, 2023 | 05:00 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Tachometer
Tachometer is overreading rpms at all engine speeds; engine is turning over at normal rate; the faster I drive, the more the tach overeads geometrically. The speedometer is okay. For a while the tach would cut in and out in its overreading; noe it's all the time. Suggestions?
Old Oct 4, 2023 | 10:05 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Tachometer
Up top, sticky, '90 - '92 tach fix...
RBob.
ZackZ420
Jun 7, 2018 10:37 AM
breathment
Apr 25, 2002 11:10 AM
