What does this wire connect to?
Old Oct 21, 2023 | 05:47 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
1988 GTA this wire is on the passenger side. Anyone know what it goes to?
Old Oct 21, 2023 | 07:13 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: What does this wire connect to?
If it reaches over far enough, it looks like the wire that goes to the door switch, to turn the interior lights on when the door is opened.....
Old Oct 23, 2023 | 08:09 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
If that wire is for the door jam switch you could check for continuity on the white wire for the courtesy light you have hanging there
Wayback Machine (archive.org)
Old Oct 23, 2023 | 06:01 PM
vf750rider's Avatar
Car: 1992 Teal RS
Engine: 350 Carbed
Axle/Gears: 4th Gen Rear 3.42
A good bet - wiring diags show door jamb wire as white, and the spade terminal is not insulated so it would logically connect to a ground (door open, switch closed, ground made for courtesy lights).
88BLKTransAmGTA
Oct 21, 2023 05:46 PM
Mspangler
Sep 15, 2022 03:24 PM
germ83
Jun 2, 2004 07:35 PM
89transam
Jun 12, 2003 04:16 PM
