VATS Issue - 1992 RS - bypass installed
Old May 19, 2024 | 05:46 PM
mcjanemarie's Avatar
I’ve installed the Gator VATS bypass. I went through all the resistances(not able to read the chip via OHM), no luck - however, only one resistance did cause the “security” light to go out after a few seconds - the other 14 options did not. What I want to know, would that be the correct resistance even though it didn’t start and we are probably looking at a deeper issue? TIA!
Old May 19, 2024 | 06:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: VATS Issue - 1992 RS - bypass installed
Why not just bypass the starter enable relay and get a tuned chip ? Just curious why fussing with bypassing the key cylinder reader ?
Old May 19, 2024 | 07:00 PM
Thanks for your response, it seemed like trying the bypass module was the easiest solution.
Old May 19, 2024 | 07:03 PM
Engine: Lb9
Transmission: M20
So the gator sends a hz signal to the ecm ? Or it just has switches to send 1-15 different ohm readings to the passkey module?
Old May 19, 2024 | 07:15 PM
Yes, the Gator sends 1-15 ohm resistances to the pass key module.
Old May 19, 2024 | 07:26 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Sounds like on the value where the Security light goes out, you are successfully simulating the key. If the start enable relay has physically failed, it will still prevent the juice from going to the starter. You can remove the relay and install a bypass with 12ga (or something, it's thick) wire and two male spade terminals to test this.
Old May 19, 2024 | 08:00 PM
Engine: Lb9
Transmission: M20
wow just looked it up, just a few dollars of resistors for $100 bucks ouch 🤕.
jumper the starter enable relay large gauge green to large gauge yellow under the driver side kick panel and go back to the resistance that turned off the security light as suggested.
Old May 20, 2024 | 08:50 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
So glad my 1984 Trans AM does not have VATS
Old May 20, 2024 | 03:11 PM
Yes, you are a lucky one. It's a pain in the ****!
Birdsong_'89_RS
Nov 11, 2006 05:02 PM
damen
Sep 25, 2002 05:19 PM
Garett92Z
May 8, 2002 05:33 PM
91blkta
Apr 22, 2002 11:22 PM
