testing VATS?
Old May 8, 2002 | 03:15 AM
Garett92Z's Avatar
testing VATS?
Hey guys.
I'm not sure if the VATS in my car's hooked-up right or even working. it'sa 92 Z28 I picked it up in October...
the Security light comes on when i start it up then goes out... anyhow... there is a little car alarm type thingy on the driver's side inner-fender in the engine bay.. an alarm of SOMe sort.. is this VATS?
what's an easy way to test the VATS in my car?
garett
Old May 8, 2002 | 11:09 AM
tpi_roc's Avatar
get a key cut with the right pattern but without the chip
if the car starts vats no workie
Old May 8, 2002 | 05:33 PM
pontiac's Avatar
starting procedure is correct - light comes on and disapear - your VATS is doing just fine. there's no alarm in VATS, so probably you were looking for some another things around right fender. VATS simply disable injector driver when activated, so it's quite elegant in that way :hail:
-P
gta892000
Aug 11, 2019 11:16 AM
RedLeader289
May 28, 2019 01:47 PM
NZKnight
Oct 15, 2015 02:47 PM
Eric-86sc
Sep 28, 2015 11:37 AM
raymondandretti
Sep 27, 2015 06:43 PM
