Electric speedo odometer/trip meter not working
Old Jun 25, 2024 | 10:21 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I've searched and have found a lot of information on the mechanical speedo but I have the electronic VSS one. Not the digital dash. My odometer and Trip meter stopped working but the speedometer works fine. Any solutions for this one?
Old Jun 25, 2024 | 10:39 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Electric speedo odometer/trip meter not working
Think I found the problem. There appears to be an electric motor that drives the gear set that turns the odometer. Looks like one of the gears has broken teeth.
Old Jun 25, 2024 | 02:54 PM
OrangeBird's Avatar
Car: 1989 Firebird
This may or not be what you need, I post it to give you a glimmer of hope that there may well be replacements for those gears if ya get lucky in your search.....
https://www.shapeways.com/product/KA...googleshopping
Old Jun 25, 2024 | 03:06 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks! I'll check that out. Great find.
Old Jun 25, 2024 | 10:48 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
I was aiming to reply earlier. I got busy and caught up with things today and sweating ***** outside fried my brain and I forgot to get back to your thread. My friend and I have run into this same problem before with our Firebirds. There is a company that makes a kit to fix this with instructions. The gears in this kit are real injection molded gears not 3D printed. Works like a charm to fix the issue a little bit delicate to do.
EDIT: Here it is.
Odometer Gears - Firebird Odometer Gear Kit
Also there are a ton on threads on here about this problem on Firebirds with detailed pictures and instructions.
Firebird Odometer - Broken, but is there a fix?
OMG I just noticed you are in Canada. I guess your Firebird has Metric gauges. If so the Kilometer version of this gear kit isn't ready yet.
Available Soon
Estimated Date: 07/31/2024
Old Jun 26, 2024 | 06:13 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
EDIT: Here it is.
Available Soon
Amazing info, thank you! I don't understand why the U.S version wouldn't work in the metric car. I have a 140mph speedometer. It's just the smaller numbers on the scale. in kilometers that's 220, which has 140 right below it.
Old Jun 26, 2024 | 07:18 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Never mind. Caught my mistake. The odometer will count differently.
dark scorpion
Jun 23, 2009 11:27 AM
Erick
Jun 26, 2005 11:16 AM
ViciousZ
Oct 13, 2000 07:24 AM
