SGI-5 Speedometer Converter box odometer
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I wired this up a couple of years ago, works fine usually even if it's a bit glitchy. But it definitely indicates the correct speed most of the time. The question I have is, why doesn't the odometer work? I wired it up according to the instructions and the speedometer works, so I had assumed the odometer would be linked to the speedometer, but apparently it isn't. Has anyone else dealt with this before? The car is carbureted with a T56 at this point, so maybe it has something to do with the ECM being removed?
The closest thing I can find to a wiring diagram is this:
https://austinthirdgen.org/storage/diagram_1992_gauges_part5.gif
https://austinthirdgen.org/storage/diagram_1992_VSS_V6_vinT_and_V8_vinF_and_vin8.jpg
It just worked before my T56 swap and then it didn't. I cant find any explanation for it.
None of these indicate there are any extra connections to make with the SGI-5 so Im stumped.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: SGI-5 Speedometer Converter box odometer
Your plastic gear that drives the odometer is probably broken like so many are. There's a kit available to replace it. You need to take your speedo out to check
Car: 1992 Camaro RS
I did manage to find the replacement gear, so thanks for pointing me that direction.
