Speedometer: works SOMETIMES
Old Apr 1, 2019 | 02:37 AM
micktroup's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Occasionally, when I start up, the speedo doesn't work- just lays there like my ex-wife! Then, while I'm driving, suddenly it starts working. Anyone have a fix or idea of the problem?
Old May 6, 2019 | 03:50 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
VSS Mess
It can be a loose connection anywhere from the VSS to the inside of the IP, but most likely a failing VSS or bad connection going to it.
This one is going to take good old fashioned looking and wiggling wires.
You can inject a signal into the VSS connector then trace and wiggle until the problem occurs.
Happy Racing !
Funny Car Fun Fact: From a standing start, Funnys accelerate faster than a fighter jet.
Old May 6, 2019 | 04:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Speedometer: works SOMETIMES
Originally Posted by micktroup
..... just lays there like my ex-wife! .......
Funny , she moves just fine for me !!!!!
Sorry , , couldn't resist and had to beat Drew to the joke
Old May 6, 2019 | 11:35 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You *might* also have some bad teeth on the speedo gears. Only way to know is to pull the VSS from the tail-shaft housing and inspect BOTH of the speedo gears. ( 1 on sensor and 1 inside the sensor hole on tail-shaft. )
chekbaka
Nov 20, 2003 05:57 PM
Wezzeles
Jan 15, 2003 09:10 PM
88fbird
Dec 23, 2002 10:15 PM
Jokerman
Aug 11, 2002 12:02 AM
DANIELEK
Dec 11, 2001 03:26 PM
