82 wiper motor
Old Nov 12, 2024 | 06:16 AM
Sactodreamer's Avatar
Car: 84 Trans AM W62
Engine: 5.0
82 wiper motor
I haven't been able to find this anywhere. All I need is a picture of a 82 wiper motor mounted to the firewall. I don't have the plugs and just need to know what colored wires go where.
All of my local wrecking yards have 84 and newer and appear to be different.
Mine has an "L" shaped plug with 3 wires and a flat plug with 3 wires.
I was able to find this Pic which should take care of the "L" shaped plug with yellow, pink, green.
The flat should be yellow, purple, and gray.
Old Nov 12, 2024 | 07:00 AM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: 82 wiper motor
The motor off 79(?)-81 f body's will work. I know the motor is the same. The electronics I believe are the same as well. There a couple of options. You can use the stock electronics and purchase a motor w the cover/electronics or hawks and a few other companies make an upgrade that makes the washer pump electronically driven vs driven off the wiper motor.
the 84 and newer have a different motor/mounting and the electronics are totally different.
the 82/83 cars are more of a mix of second gen's.
Old Nov 13, 2024 | 11:56 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 82 wiper motor
Here is a wiring schematic for the 82-83 Wiper system,... Hope it helps !
Old Nov 13, 2024 | 08:29 PM
Engine: 5.0
Re: 82 wiper motor
I appreciate the wiring diagram but that doesn't help me without seeing a physical plug. That diagram doesn't tell me where the wires go onto the wiper/washer motor.
Old Nov 13, 2024 | 08:47 PM
Car: 82 TA
Re: 82 wiper motor
How's this
Old Nov 14, 2024 | 01:12 AM
Engine: 5.0
Re: 82 wiper motor
More help, thank you!
I think this is the order from what I can tell.
Fronzizzle
Sep 11, 2018 12:55 PM
TheIgnitious
Jul 19, 2014 02:28 PM
redfire82
Feb 2, 2007 01:53 PM
Randy82WS7
Aug 21, 2004 11:52 AM
