So how would you wire in a dakota dash
Old Apr 25, 2025 | 04:03 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
The control box has to go somewhere. The wires have to hook up to something.
I assume I would just zip it up underneath the drivers dash somehow. And then run wiring to/from the ECM? Assuming everything that a cluster needs is also wired into the ECM. That would make it a lot easier.
A wiring diagram would be nice as well.
Old Apr 25, 2025 | 04:21 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: So how would you wire in a dakota dash
i put the control box behind, above or below the cluster in the dash where it fits best.
Old Apr 28, 2025 | 03:42 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Just use all the wires from the factory gauges and move them over to the Dakota stuff. That's pretty much what I did when I wired up my Autometer gauge cluster
Old May 4, 2026 | 05:39 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I put this project on hold, while i did some alternator and fuel pump stuff. But now i want to get back on it. If anyone has any pictures of their completed project, id love to see.
Old May 4, 2026 | 05:47 PM
thatsupnow's Avatar
Probs want to talk to @bk2life
Old May 4, 2026 | 09:09 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Check out this thread for some input:
https://www.thirdgen.org/forums/ltx-...ml#post6502414
Mfitz81
Aug 5, 2017 10:18 AM
talover111
Sep 24, 2013 07:10 PM
