Headlamp ground location
Old Dec 29, 2025 | 12:50 PM
steve40's Avatar
Anyone know what hole behind the headlamps where the grounds attach to?
Old Dec 29, 2025 | 01:12 PM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Re: Headlamp ground location
You are in luck. I just painted my core support and fender wells this Saturday and started putting the harness back in place on Sunday. There are two grounds points. One wire on the driver's side behind the high beam, the hole closest to the radiator. Two ground wires on the passenger side behind the high beam, the lowest hole.
Old Dec 29, 2025 | 07:21 PM
steve40's Avatar
These holes?
Old Dec 30, 2025 | 09:01 AM
ACebell's Avatar
Transmission: TH350
Axle/Gears: 323
Nope - 1st picture, top left hole. Second picture, from your circle, look straight up and there will be a similar hole like the 1st picture.
Old Dec 31, 2025 | 07:26 PM
vorteciroc's Avatar
Top Answer: 1
No matter where you decide to connect the ground wires...
There needs to be a clean, bare metal location (remove any paint) for a good connection with low resistance.
Do Not just attach a Ground Eyelet to any unprepared surface with paint on it!
Old Jan 2, 2026 | 08:33 AM
And use a star washer between the terminal on the wire and the bare metal surface; and apply something to manage corrosion of bare metal such as NoOx, dielectric grease, etc..
usafirebird
Exterior Parts Wanted
Mar 23, 2022 07:19 AM
Mad Max
Jul 4, 2012 12:48 PM
z28breh
Jan 14, 2011 10:04 PM
alxtre99
May 25, 2006 10:53 PM
