My Blinkers!!!!!!
Old Jan 29, 2002 | 08:35 PM
naachoo's Avatar
My Blinkers!!!!!!
ok right now i bought my 92 camaro about 2 weeks ago and its in perfect shape, but the turn signals keep blowing fuses, it will work but then when i am driving it will blow when i attempt to use it most of the time, i dont know if this is a common problem but there is also a clifford alarm in the car and no remote, so it is always armed, so when u open the doors the turn signals still flash even when there is no fuse in the fuse box for the turn signal. vary weird. could the alarm be the cause?
thank you all that can help
Old Jan 29, 2002 | 09:32 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Do all of the signals blink when you open the doors? There might be a wire touching a ground somewhere. Another thing to look for is the reverse lights, they are on the same fuse as the blinkers, do they still work? Is it connected at the shifter? I doubt the alarm is to blame.
Welcome to thirdgen!
-Matt
Old Jan 30, 2002 | 10:18 AM
naachoo's Avatar
my blinkers!!!
Yes, when i open my doors they all blink, well this is what i am gonna do right now, i am getting a new viper alarm put in since the other alarm will not accept a new remote maybe it will fix it, but it uses a 20 fuse, when i got the car i noticed a 25 was in and it workd for quite sometime, if i put another one of the 25's in will it over heat the wires for the signals?
where would some good places be to get this fixed?
thanks a ton
Old Jan 30, 2002 | 10:53 AM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
Do your reverse lights work still? I'm thinking if it's not the reverse lights than it must be something with the alarm wiring. If this is the case any alarm installer can fix it.
-Matt
Old Jan 30, 2002 | 11:12 AM
mtccl's Avatar
It is part of the alarm sounds like. Most alarms make you signals flash when the alarm is sounding and they flash the signals when activating. They do this by energizing the signal wire with the alarm box. Find where they spliced into the signal wire and disconnect.
Old Jan 30, 2002 | 12:22 PM
naachoo's Avatar
my blinkers!!
well i am not shure at this point if the reverse lights work. but i am on my way to checking that out, but thanks for all the info. u helped more than any one else has, one thing i am just not shure of, if i put a 25amp fuse in will it make the wires to hot and runin them?
also Flash84Z28 i like u'r car, what are some easy and good mods i can do, i have k&n filter and new exhaust(stright Pipes). what elese is cheep and worth the money?
thanks
aaron:hail:
Old Jan 30, 2002 | 07:23 PM
Flash84Z28's Avatar
Engine: mild 350
Transmission: TH350
I accidently had a 25 amp in there and it dien't hurt anything so go for it, until you get the problem resolved. Go post or do a search in the Tech/General Engine forum for some easy quick mods to go. I don't know if you have TPI, TBI, or are carbed so the best mod to do may vary. If you've got exhaust go ahead and start modding the intake system...like a throttle body, air foil, or carb. Maybe an ignition box or some new polyurathane brushings or newer performance suspension products. It really depends and you will get a bunch of differant options. In fact I think there is a thread called "What is the best mod for under $100" You might want to check that out too.
Thanks for the...compliments e-mail me anytime,
Matt
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
