How can I wire the fuel gage to work if I cut wires to fuel pump
Old Feb 10, 2002 | 06:10 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I had to disconnect the factory fuel pump wires on my GF's 89 RS when I swapped it to carb because the damn thing would only stay on for a few seconds then turn off, so I hard wired it to run by running a wire from the fuse box and spliced it into the fuel pump lines behind the back seat. Problem is now the gage doesn't work. Any ideas??
Old Feb 11, 2002 | 12:47 PM
mat89RS's Avatar
Easy, check behind the back seat, remove the carpet, there will be 3 wires, 1 gray, 1 black and 1 white I think, just take the white one and rerun the wire up to your fuel gauge.
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Irocohio
Aug 12, 2015 08:03 AM
apie2546
Aug 8, 2015 07:12 AM
