timing lights (dumb ?)
Old Feb 22, 2002 | 04:47 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
I have a 92 rs with an lo 3 i need to set the timin, whats the dial on the back of the timming lite for?
Old Feb 22, 2002 | 12:25 PM
1986redbird's Avatar
I believe thats to check and see what the advance on the timing is (old style mechanincal or vacuum advance), with our cars I don't think you need it so just set it to zero. make sure you disconnect the wire to the computer when setting the timing so the computer doesn't fight you while doing it.
Old Feb 22, 2002 | 06:16 PM
bubbareno's Avatar
Transmission: t-5
timing lights
thanks, it passed inspection today dident even touch the timing. the said it was runing great.
Old Feb 27, 2002 | 01:43 PM
John+91'Z_4ever's Avatar
Actually, dumb is not being able to speak.
Old Mar 3, 2002 | 11:30 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The dial on the back of the timing light allows you to read timing advance beyond the 12 degress, or so, indicated on the timing mark on the motor - whih is handy if you don't have timing tape on the dampner, or a fully marked aftermarket dampener. You turn the dial until the mark lines up with zero degrees & then read the dial for timing advance.
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
