Blower Motor
Old Feb 22, 2002 | 06:22 PM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
Blower Motor
Ok... i go to the store, warm up my car, and come home. Turn off the ignition... and the blower motor keeps going. I start the car, turn it off again... blower motor keeps running. I mess with the a/c controls... the setting switch (hi/lo).... keeps running. To solve it i went under the hood and disconnected the wires leading to the motor. Now... i have no heat because the blower won't work, and getting out of the car to turn on the blower seems a bit silly to me.
Q: Why is the blower motor running even when the ignition is off?
Any help here would be appricated.
Thanks,
Joker
Old Feb 25, 2002 | 11:13 PM
2vmodular's Avatar
bad ignition switch, poor remote start system install, ignition lock -> switch linkage out of alignment or bent, etc..
check HTR A/C Fuse in drivers side fusebox, should only be hot when ignition is in run position
Old Feb 26, 2002 | 02:15 PM
ATOMonkey's Avatar
Check the blower relay that is in the air box. If that is shorting it will also keep the fan on.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
