fuel pump wire?
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
fuel pump wire?
Where can I find the end opposite the tank, as I want to run this pump with a return regulator and I need to pick up the wire for a switch. ecm is gone, where is it under dash?
Car: 91 RS B4C
Engine: 355
btw, the car was a tpi 91rs. There is a connector near the steering column, its not connected to anything and has several wires in it, tan, green and others. also need wire for sender. thanks for any help
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
