TPI harness questions
Old Mar 3, 2002 | 11:39 AM
Dragula's Avatar
I just pulled the entire TPI harness and computer in preparation for my 383ci carb swap. Am I correct in assuming that I do not need any part of the TPI harness? The necessary connections all come from the drivers side firewall (alternator, lights, wipers, etc)
Also, the harness had four bundle connections under the dash: 2 went to the computer and the other two go where? One was a 3-wire bundle and the other is a 14-wire bundle. I know that somewhere in there is the service engine light (3 wire?) and the 14-wire bundle maybe controls the gauge panel?
Either way, these were all part of the TPI harness. I should be good to go wiring everything as long as I put new gauges and sending units in, right? The TCC lockup will be controlled by a vacuum switch on my StreetFighter.
Thanks for any help you can offer.
Old Mar 3, 2002 | 05:51 PM
Dragula's Avatar
Anyone? The only thing I can think is the 14 wire runs the temp sender, tach, etc....
Old Mar 7, 2002 | 06:27 AM
DaveK's Avatar
One connector goes to the burnoff module mounted piggy back to the ECM.
The 3 wire connector I know one goes to the ALCL connector. Not sure about the other two wires in that connector.
Old Mar 8, 2002 | 03:01 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
ECM to Chassis connector pin outs:
Rectangular chassis connector male pin view:
__ __
A B C D E F G H
J K L M N P R
Square chassis connector male pin view:
A B C
F E D
'84 Auto trans, rectangular connector
A Brown; Air solenoid switch to ALDL connector; pin C
B Open
C White / green; To check engine light
D Open
E White / black; ALDL connector diagnostic enable
F Pink / black; Ignition power from 10 amp fuse to ECM & air solenoids
G Open
H Tan / black; TCC lock signal to ALDL connector
J Open
K Brown; VSS output to ECM
L Open
M Black / White; Ground for ALDL connector & park / neutral switch
N Orange / black; Park / neutral switch
P Purple; Power to TCC from TCC power switch at brake pedal
R Pink / black; Gauges fuse ignition power to throttle kicker relay
'85 Auto trans, square connector
A Pink / black; Fuel injector power
B Open
C Brown; Primary fan relay
D Pink; Fuel injector power
E Open
F Open
'85 Auto trans, rectangular connector
B Red / black; Fuel pump relay NC contact
C Brown / White; SES light
D White; Fuel pump relay common contact
E White / black; ALDL connector diagnostic enable; pin B
F Pink / black; Ignition power to ECM
G Pink / black; Ignition power to air control solenoids
J Orange; ALDL connector serial data from ECM
L Open
R Purple / white; Cold start injector power; hot in start only
'87 Manual trans, square connector
B Green; Reverse lights (man trans only)
D Pink / black; Fuel injector power
E Open
F Blue; Reverse lights (man trans only)
'87 Manual trans, rectangular connector
B Orange; Fuel pump relay NC contact
D Brown / white; Fuel pump relay common contact
G Tan / purple; Ignition power to air control solenoids
H Open
L Open
N Open
P Open
'92 Auto trans, rectangular connector
A Open
B Pink / Black; LH fuel injector bank power from 10 amp fuse
C Brown / white; SES light
D Gray; 4000 pulse / mile VSS output from ECM to speedometer
E White / black; ALDL connector diagnostic enable; Terminal B
G Pink / Black; RH fuel injector bank power from 10 amp fuse
H Tan / black; TCC lock signal to ALDL connector; Terminal F
J Orange; Serial data from ECM to ALDL connector; Terminal M
K Open
L Blue; Pass key module signal to ECM
M Open
N Orange / black; Park / neutral switch to ECM
P Red; 2000 pulse / mile VSS output from ECM to cruise control module
R Open
Old Mar 8, 2002 | 03:19 PM
CDN_87IROC's Avatar
Now thats the complete type of answer we wish all questions were handled ! good work TIm.
Old Mar 8, 2002 | 05:11 PM
kabar14342's Avatar
are you cutting apart that tpi wiring harness? im in need of one, if your not using it and its in good condition let me know if you will sell it cheap, my projects slowly dieing due to college and lack of funds, let me know
matt
Old Mar 9, 2002 | 01:22 PM
Dragula's Avatar
Thanks for the info!:hail:
The harness is already sold....sorry.
Caspar
Jun 19, 2016 11:19 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
