What do I do now??
Old Mar 8, 2002 | 01:17 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
What do I do now??
I just got a new cap and rotor from Hypertech, and a new coil from MSD.
2 problems....now it's my understanding (from previous experience) that the rotor should just come right off by pulling up on it?? This one is so nasty that it won't come off....do I risk anything by trying to use a wrench and yanking it off???
2.) The new coil needs to go on the mounting braket so it can be attached to the manifold, but the bracket is attached to the original coil by some other means than a screw. It mentions something about "that riveting might be necessary." Now I'm not totally into the lingo, but isn't riveting mean that I need to drill that crap out??? If so, what size drill bit do I use. MSD, seems to have provided screws and nuts for afterwards......why can't they just supply the new bracket as well.
Help???
Old Mar 8, 2002 | 02:46 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You may find it easier to remove the distributor if the rotor is being difficult to remove. You will have to grind off or drill out the rivets that hold the stock coil in place in the bracket. Use one of the mounting holes in the MSD coil as a gauge to select the correct drill size.
Old Mar 8, 2002 | 03:19 PM
Car: 91 RS
Engine: 350 TBI
Thanks for your help, but I got it. :lala: Nothing a hammer and screwdriver couldn't handle. That taste of victory is sweet!! I have defeated the rotor and the coil.:lala:
