code 43.. i swear im going to kill it
Old Mar 11, 2002 | 04:12 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
ok.. well i keep getting this code. dont know why. my whole ignition system is aftermarket. everything is firing fine. but every day or every other day ill get a check engine light and its this code. the guy who i take my car to checks the car out.. finds nothing wrong and clears the code. *btw he/his shop only works on 82-02 f-bodys and vettes, so he knows his **** when it comes to TPI*
Old Mar 15, 2002 | 12:42 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Code 43 is an ESC circuit code If the ckt 496 is open or shorted for .5 sec it will set a code, it could be a bad knock sensor connector or any other connector with a bad connection. Check the grip of the male to female pins on the connector and check associated wiring.
Old Mar 15, 2002 | 12:45 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
is this a must fix if i want to get nitrous *150 shot* or is this just a annoying code?
Old Mar 15, 2002 | 01:47 AM
92BLKL98's Avatar
For running nitrous you probably want it fixed. look around at your connectors you may get lucky.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
