New tach won't work.....
Old Mar 20, 2002 | 01:32 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Okay i installed a mini-tach in my gta because the digital tach is a)inprecise and b) quits at about 3500 rpms. Well i wired it up just like it said in the instructions and when i run the engine, it doesn't read anything. I checked the power and grounds to the tach and they're fine. I spliced the white tach (???) wire on the coil for a signal. It says in the instructions that you are supposed to a)tap into the signal from the existing tach wire or b)from anything on the "negative" side of the coil. Can someone shed light on this for me?
$750 L98
Feb 1, 2025 02:25 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
Eric-86sc
Sep 28, 2015 11:37 AM
