Trunk struts, brake light and reverse gears...
Old Mar 25, 2002 | 08:45 PM
zaid_oc's Avatar
I don't know how to begin this.
Here it goes...
I needed new struts for trunk of my Camaro. I took the old ones oout and drove for about a week without struts(very heavy trunk doors.) Everytime I closed the trunk it made that suction noise. it pulled the door tightly shut(air tight, i guess.) I installed new struts for my car today and now thier is no electric into my trunk.
I close the door and it pops back up. The door hook touches the latch, and when it is supposed "to suck the door airtight" it doesn't. Instead the door pops back up. Also, the 3rd brake light doesn't work (The rectangular one on the top.)
And, I am not sure if it is normal with all Camaros:
1. My car is AT and when i shift to reverse i have to "shift the gear into reverse then push it up so the reverse ligths stay on." If i don't the car is still in reverse but the white lights are out.
pLz HELP! My trunk is valuable to me.
Old Mar 25, 2002 | 09:08 PM
ThirdGen Stoner's Avatar
Well I dont know if this has anything to do with it, but i know on my struts, there are plugs that plug into them. Maybe you forgot to replug them?........
Probubly just a nother stupid reply from me though...
Old Mar 26, 2002 | 04:35 PM
Z28DJP1987's Avatar
The plug on the hatch strut is for your rear defrosters and not the brake light.
Old Mar 26, 2002 | 06:32 PM
See.......told ya.
Thanks for clearing that up though.
Old Apr 3, 2002 | 02:13 PM
dans87ta's Avatar
Car: 87 trans am, 93 full size blazer
Engine: 5.0, 5.7
Transmission: A4
I dont know about your hatch struts, but as far as the whole reverse thing, my car does the same thing. I think its just how the switch is aligned in the shifter. I have never been really bothered by it, and I think a lot of our cars do this.
Old Apr 4, 2002 | 01:20 PM
82camaro's Avatar
Car: 82 camaro SC
Neutral safetly switch(also reverse light switch) gets worn and the reverse lights don't always light up. Common problem. Check the bulb and wiring for the third brake light(I assume the regular brake lights work). Check the fuse and maybe the wiring for the hatch latch.
colton_carlson
Mar 8, 2019 12:21 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
