digital dash not working right.
Old Mar 26, 2002 | 03:36 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I just recently bought a GTA with a digital dash, and within a few hundred miles, the odometer started intermittently going off. Not recording mileage, just kinda going blank. Then the odometer quit working altogether. I also noticed that by the tach there is a box which is supposed to display something, probably the actual RPM in numbers, but there is nothing there. The speedometer still works. Any ideas what the problem could be or how to fix it? I sure hope I don't have to replace the whole dash.
Old Mar 26, 2002 | 11:28 AM
ROB87GTA's Avatar
i have a similar problem,ihave no milage/odeometer readings just
a blank face also my speedo works but just random numbers not
relating to my actual speed.
Old Mar 28, 2002 | 12:45 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds like an intermittent problem within the cluster, itself. You may want to disassemble it & check the PC board interconnects & also reflow all of the solder connections on the display PC board.
Old Mar 30, 2002 | 09:24 AM
ROB87GTA's Avatar
Tim
Thanks for the reply,it will take a little while to get round to it
as the GTA is my daily driver.
Are the speedo and mileage/odometer connected somehow
via the same circet?
Old Mar 30, 2002 | 05:21 PM
polishdevil's Avatar
Car: 88 GTA
I have the odometer problem in my GTA. It goes on when i first start the car up, then after drving around it turns off.
My dad had a GTA back in the day and his odometer didn't work for about 4 years, then it turned on and off again.
Dave
Old Feb 3, 2003 | 01:17 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
hey guys,
i know that the boz on the tach screen to the uppper left is the screen where the "up shift" light comes on if you have a manual trans car. i'm glad my dash works for the most part still even though the numbers on my odometer sometimes fade in and out while driving.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tartagliaz28
Aug 15, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
