Wiper Washer
Old Mar 27, 2002 | 09:21 AM
mike86bird's Avatar
Wiper Washer
Hey i put some fluid in for my window washer, it doesnt come out i can hear the washer motor but nothing comes out?
help?
thanks,
:hail: :lala: :hail:
Old Mar 27, 2002 | 11:16 AM
Maro's Avatar
Sounds like your washer motor has gone. Happened to me, you have to replace the pump. On my Camaro, it's on the drivers side, just below the wiper motor. It slides out of the bottom, and you slide a new one in.
Old Jul 23, 2002 | 04:24 PM
cherrybomb86's Avatar
did you ever find out the problem? i currently experiencing the same thing
Old Jul 28, 2002 | 04:48 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
no
I've been playing with it and it started working
But then it stoped squirtin again.
Old Jul 28, 2002 | 06:29 AM
Z28DJP1987's Avatar
With mine unless I use it weekly it will dry out from the engine heat, and needs to be reprimed to make it work. Or a bad pump.
Fireslash
Apr 11, 2016 06:43 PM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
