Input and Output locations of ECM
Old Mar 27, 2002 | 06:00 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Does anyone have or no where i can find the input and output ECM locations on a 89' IROC 350 TPI ?????
Old Mar 27, 2002 | 09:00 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
What are you meaning buy input & output locations. Wires or like the ALDL connector ?
Old Mar 27, 2002 | 11:32 PM
Car: 92'Camaro RS
Engine: a loud one
yes..the aldl connector
Old Mar 28, 2002 | 06:22 AM
Jza's Avatar
Jza
The ALDL diagnostic enable is pin A9 on the 165 ECM found in a stock 350 TPI IROC. It runs through pin E on the IP connector, to pin B on the ALDL connector. That's effectivly the ALDL "input".
When that pin is grounded the ECM goes into diagnostic mode. The serial data pin is A8 and it goes through pin J on the IP connector to pin E on the ALDL connector; and the SES light is pin A5, which goes through pin C on the IP connector to the SES lamp on your dashboard. Those are effectively the "outputs".
Other "inputs" for the ECM are the TPS sensor, MAF sensor, MAT sensor, CTS sensor, O² sensor, and the knock sensor via the ESC module.
Nick McCardle
Sep 10, 2015 08:36 PM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
raymondandretti
Exterior Parts for Sale
Sep 5, 2015 05:02 PM
tonys91rs
Sep 2, 2015 07:07 PM
z28guy134
Sep 1, 2015 11:50 PM
