A/C blower on constantly...
Car: 2007 Saturn Sky Redline
Engine: 2.0 turbo
Transmission: m5
Axle/Gears: 3.91 LSD
I had major wiring issues in my car so I went through and tried to fix as many as I could... So in doing as much I decided to remove the A/C and install an a/c delete box. Of course I had to remove the A/C blower and put in a non-a/c one. The problem with this is that now after being hooked up, and having a ground not on the motor but rather being grounded to the frame, the blower goes on FULL SPEED when the battery is on. when you turn on the ignition however the blower goes off, and you can turn the blower on and off with the controls (on high or off completely) What might be causing this? I tried grounding in a few places... but I did have to splice in one of the wires to the relay as the old one was all cut up that went to the relay from the resistor. Any ideas would be greatly appreciated.
Thanks,
Inwo
Thanks,
Inwo
codeysabatini
Nov 10, 2015 04:07 PM
2012sergen11
Oct 13, 2015 07:38 PM
buckeyecelt
Sep 24, 2015 05:50 AM
