knock sensor wire
Old Apr 11, 2002 | 09:43 PM
jeff85iroc's Avatar
knock sensor wire
ever since i have had my car it has had a pinging problem.
I got a new oxygen sensor and a new knock sensor but my question is i got under the car to change my knock senor and the the wire was already disconnected.Ok this might be the problem
so i change the sensor and i grabbed the wire to connect it and it come out in my hand!I thought oh ****i broke the wire but when i checked it it was a straight. Anyway how can i find out where this wire comes from or is there an easy way to connect it through somewhere else.
Any help would be GREATLY apreciated.
Jeff
Old Apr 12, 2002 | 12:07 AM
jeff85iroc's Avatar
can i just join the blue wire that connects to the knock sensor up to the blue wire on the ESC.Seems like the easiest way unless i am missing something
It is just a straight bit of wire between the knock sensor and the ESC is'nt it.
Jeff
Old Apr 12, 2002 | 04:44 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The wire is straight run from the ESC
This is a general TPI diagram (87 TPI others similar) http://www.deadbird.org/tech/87tpi02.gif (assuming that's what you have)
Old Apr 12, 2002 | 09:24 PM
jeff85iroc's Avatar
Thanks deadbird i thought it was but just to be safe i thought i would ask.
Cheers
Jeff
Old Apr 12, 2002 | 09:37 PM
deadbird's Avatar
Engine: TPI 305/ v6
No problem
Cheers !
Caspar
Jun 19, 2016 11:19 PM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
