Whats a prom?
Old Apr 12, 2002 | 04:04 PM
Camaro68Vette63's Avatar
Car: 1992 Z-28 Camaro
Engine: LB9 305 TPI
Whats a prom?
Can someone please tell me what a prom is. I think it has something to do with the computer chip.
Old Apr 12, 2002 | 04:21 PM
86IROCZ's Avatar
programable read only memory. It's the 'chip' you always hear about. ie "I just put a custom chip in my car"
or it's that dance at the end of High School where everybody "gets some"
Old Apr 12, 2002 | 09:43 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
That's so funny, lol.
Anyways, the PROM is the memory chip that's in the ECM and it has all the calibration about the specific car such as size, weight, engine size, gear ratio, transmission type, emissions, etc... The ECM uses this information and helps the ROM (read only memory) which is the core program to make decisions about the operation of the car. The ROM in turn also has basic instructions that tell the ECM to do something specific whenever is sees a specific input. Confussed?
Example: The engine temperature raises and the coolant temperature sensor detects the change and the ECM receives the signal, according to this change the ROM will command the ECM to change fuel to air ratio or timing advance in accordance to the information stored in the PROM. If a custom PROM is used because the engine was modified then the ROM will react different due to the information stored in the PROM itself.
Now this is my understanding of what it is, and what it does. Hope I didn't confuse you.
Ozzy
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
