NEEDED T56 PARTS
Old Mar 5, 2008 | 09:17 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Transmission: Tee five six
Axle/Gears: 10 Bolt 4:10's
NEEDED T56 PARTS
I need the clutch master/slave cylinder for a 1994 trans am T56... Also, if anyone would be willing to sell the custom T56 crossmember for a 1992 camaro it would be much appereciated
Old Mar 6, 2008 | 10:58 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: NEEDED T56 PARTS
I got one from Spohn...just the crossmember. No driveshaft loop or torque arm mount. $80 plus shipping
Old Mar 6, 2008 | 11:07 AM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
Pics? I am definately going to buy that from you, I just wanna see it first. I really appreciate it dude
Old Mar 7, 2008 | 10:21 AM
wesilva's Avatar
Transmission: 200R4
Here they are.....
As you can see, it was originally one that had provisions for the torque arm but that piece got sawed off. It would be an easy piece to duplicate if you wanted to purchase a torque arm from Spohn. Without the piece, it's only function is to properly mount a T56.
Attached Thumbnails NEEDED T56 PARTS-mvc-001f.jpg   NEEDED T56 PARTS-mvc-002f.jpg   NEEDED T56 PARTS-mvc-003f.jpg
Old Mar 7, 2008 | 12:23 PM
BrOdBaNd's Avatar
Car: 92 Camaro
Engine: El Tee Juan
What is the torque arm for? Is it necessary to have it?
Old Mar 7, 2008 | 02:53 PM
wesilva's Avatar
Transmission: 200R4
You already have a torque arm. It is mounted to your transmission and goes all the way back to your rear axle. It is one of the most important links of your rear axle to your chassis. If the T56 you have is from a Camaro or Firebird then it already has a torque arm mount. Some guys upgrade the torque arm to a stiffer unit to improve handling. Spohn mounts their upgraded arm to the transmission crossmember. Edelbrock mounts theirs to the transmission.
Read this article carefully. It explains what your looking at in installing a T56 in your car. Their crossmember is just like mine....with no torque arm mount.
http://www.skulte.com/T56.html
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
