manifold
Old Mar 2, 2008 | 06:32 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
manifold
I need a TPI lower manifold and fuel rails desperately. Let me know if you have them please. Thanks.
Old Mar 2, 2008 | 08:22 PM
Beast407's Avatar
Re: manifold
If you are interested, I have a ported stock baseplate. Also have a fuel rail assembly less injectors with adjustable regulator that needs a diaphragm and new o-rings. Price for both is $200.00 shipped.
If you would like a good used set of LS1 injectors to go with them add $50.00
Thanks.
Old Mar 2, 2008 | 08:32 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: manifold
Is the base ported to match a gasket set, or will I have to match some gaskets to it? And the diaphragm is what exactly?
Old Mar 2, 2008 | 08:35 PM
Beast407's Avatar
Re: manifold
The pressure diaphragm sandwiches between the fuel pressure regulator cover and body.
The intake runners were just opened up larger in diameter to match a set of large diameter runners I used to have.
I should add the driver's side fuel rail is set up for a cold start injector.
Thanks.
Old Mar 2, 2008 | 08:42 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: manifold
So the stock diaphragm would work with that? And I should have mentioned that I need the cold start injector. Pictures would be nice. Thanks.
Old Mar 2, 2008 | 09:36 PM
Beast407's Avatar
Re: manifold
Yes, it is a stock regulator body with an adjustable top, so the stock diaphragm will work. I believe I have a cold start injector as well. I would change all the o-rings to be safe.
Thanks.
Old Mar 6, 2008 | 09:21 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
Re: manifold
I have the manifold and fuelrails $125 shipped.
Old Mar 7, 2008 | 05:48 PM
irocz28boy's Avatar
Car: 2000 Z28
Re: manifold
No thanks. I'm getting manifold, fuel rails, runners, plenum and tb for $150 from a guy 20 minutes away. Thanks though.
db057
Jan 10, 2020 08:55 PM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
86CamaroDan
Sep 29, 2015 10:08 PM
