Complete LS1/Auto , 75,000 miles.
Old May 23, 2006 | 10:12 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Looking for $3500, but feel free to make an offer. Ebay user 'ms-fbodies', 261 100% positive feedback.
Car had 75,000 miles when I parked it, and yes I drove the car and parked it. This car was in use when I purchased it. A copy of the title is available if needed.
I'm selling this as a good swap project for all 93-97 F-bodies, but you can certainly use it in any hot rod you want. Includes the following:
Complete engine combo, MAF to tail-shaft.
Complete and uncut engine harness and PCM.
Engine cross-member with mounts as well as tranny cross-member.
Rack and pinion with rag joint.
Stock exhaust manifolds, cats, and y-pipe.
Torque arm and exhaust mount for the transmission
All belt driven accessories
Cruise control module with cable, throttle cable.
Smog pump with hoses.
Front rubber fuel lines with quick-connects.
All AC hoses.
Both radiator hoses, heater core hoses.
Also included a mostly un-cut body harness. This will include the under-hood fuse/relay panel, all the power distribution/starter cables, cruise/smog wiring, etc. The only things I know are cut from the body harness are: fan plugs, brake level plug, washer fluid plug, some lighting plugs. This harness includes the 4 connectors that plug into the engine side PCM harness.
For the two PCM harness connectors inside the car, I am including pigtails with a decent amount of cables. You will not have to splice into this PCM harness. I still have the interior harness, but more things are cut from it.
Does not include the condenser, radiator, or fans.
If you are want to purchase this combo, but do not need some of the parts (cross-member, R&P, etc) I can certainly discount the final price accordingly. Please email me to work out the details.
Everything included will be cleaned, strapped to a pallet, crated up, and wrapped in plastic. Shipping will have to be freight and is up to you. The crate will be available for pick up at a commercial address, the shipper will need to have a lift gate. I can help setup the trucking service but payment for shipping will have to be between you and the shipper.
Old May 30, 2006 | 06:13 PM
shr00m's Avatar
$3000 OBO.. Looking to sell this week.
Kevin D.
Old Jun 3, 2006 | 12:49 PM
92ls1camaro's Avatar
how much for just the ls1 long block. i have a 92 camaro that had the swap and now i need a new ls1 i killed the last one
Old Jun 3, 2006 | 07:55 PM
movieman's Avatar
Car: 1983 Camaro Z28
Engine: 383ci
Transmission: 700-4R
Axle/Gears: 3.42 10 bolt
pm sent
Old May 27, 2009 | 11:15 PM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: Complete LS1/Auto , 75,000 miles.
will you sell just the throttle cable if it's 98-99?
Old May 28, 2009 | 12:20 AM
shr00m's Avatar
Umm... Check message dates before you reply... This was 3 years ago..
Kevin D.
Old May 28, 2009 | 11:27 PM
Car: numerous
Engine: ls1, others
that's what happens when using search function. I almost replied to a couple of threads that were over a year old, didn't catch this one
RyanJB
May 7, 2016 06:23 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
MORREALE5
Sep 13, 2015 09:01 PM
funkyTA
Sep 10, 2015 06:38 PM
